Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
How to fix WiFi
The WiFi. when u connet to it won't connect jt just keeps saying saved on jt tryied reseting it and everything i knkw the wifi ks open cause i connect threw jt on my phone
Score 1
Add a comment
In smartphones you have to go your Wi-Fi settings and make sure Wi-Fi is enabled and that you are connected to the proper service set identifier using the correct security password. Make sure airplane mode is disabled and that your time and date are correct. For Windows , make sure the Wi-Fi switch is turned on, and that the device is not in airplane mode. Right-click on the network icon in your system tray and select troubleshoot problems to run the windows network diagnostic routine. Very often this will correct common issues by resetting the adapter. Also check your phone for a Wi-Fi Button or Switch.
Add a comment
Can't connect to Wi-Fi cute saying authentication problem .
Add a comment
My viking pro tablet wont let me turn on the Wi-Fi ive tried everything i can think when i go to turn it on it goes to off on its own it wont stay on
Add a comment
Add your answer
Ciara will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 5,163
