Repair and disassembly guides for the Jura (Capresso) Impressa Series J coffee maker.
23 Questions View all
Worn brew drive gear makes noise?
During rinse and also immediately after coffee flow stops there is an unusual noise that sounds a bit like a slipping gear or a loose part knocking. Any idea what could be causing this and might it be user fixable?
Score 2
Add a comment
Most Helpful Answer
Hello,
that sound is from the electric-magnet at the drainage-valve.
When the brewing stops, the fluidsystem would rinse through the nozzle
in the front and it would give many drops of coffee.
So this problem is solved by the drainage-valve, which lets the water out and air in
to stop the tripping.
The electric magnet knocks a steel-needle at a plastic cap which is mounted to
a metal axle in the valve which then opens.
Sometimes these Juras make awful humming noises while the electric-magnet
has current, too. - when these Juras get older.
As long as the knock sound and the humming is only hearable while the drainage-valve has
opened evverything is okay. :)
Friendly greets and good luck. :)
Score 3
2 Comments:
But when it rattles it could be a damaged valve.
by
The noise is a very regular knocking that lasts several seconds, so perhaps the solenoid (electric magnet) cycling repeatedly due to some fault...
by
Add a comment
Ah, yes, solenoid is the word for "electric magnet", thank you.
Look at that video, it shows a damaged brewgroup,
but you can see the action of the valve:
https://www.youtube.com/watch?v=Pxad75B2...
At 0,18 the solenoid gets current and opens the valve by pushing the metal axle. For that duration a humming noise is hearable, listen good.
At 0,23 the noise ends in the moment the valve snaps back.
If you hear fot those 5 seconds a knocking sound it is very shure that there is a problem with that solenoid, the valve or electronics.
I hope you understand me, sorry. :)
Score 2
1 Comment:
Add a comment
The brew group needs to be repaired by replacing the seals and cleaning it. Kits and instructions are available.
Score 1
Add a comment
Add your answer
Bruce Covell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 38
All Time: 5,728
