The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
69 Questions View all
How do I turn safe mode off?
Safe mode came on and now I have no volume and I can't power down my tablet.
Score 2
1 Comment:
I don't have this problem it just says safe mode in the corner
by
Add a comment
The last I heard you put a pin in where earphone goes and hold it
Add a comment
This is the second time I had the problem all right it's very simple turn off your tablet then take something sharp like an earphone or something sharp the end where it would go in in the little hole at the top where you would put the earphone what you do is you put it in you leave it there on the counter 20 pick it up push it back in at the counter 20 as you're turning it turning it on it should be fine
Add a comment
Beside headphone plug and n there is a reset hole u put a pin in and hold down for a few seconds. This should correct the problem.
Add a comment
Add your answer
jamooe48 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 848
