The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Faulty bluetooth. Where is BT module?
My Wifi works fine but my Note 10.1 2014 doesn't stay connected for more than about 30 seconds to a Bluetooth keyboard. After it drops the connection for about 5 seconds it flashes the grey notification that it has reconnected and works for another 20 to 30 seconds. Is the only way to repair the faulty bluetooth a new motherboard? The person I talked to said it is soldered on and is not worth repairing and suggested I get a new tablet. (mine is not under warranty)
Add a comment
1 Answer
Most Helpful Answer
@thuerg one does not just go ahead and try to repalce the BT module. terhe are plenty of components in the circuitry that are far more liklely to having failed. You do wabnt to porperply trouble shoot your device first. Here is the flowchart for the BT failure:
So at minimum you will need a multimeter and a capacitance tester. If you need to know where the componnts are located, please post some high res images of your board (front and back) with your question. For that use this guide. U217 is the BT/WiFi IC.
Score 2
Add a comment
Add your answer
samskees will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 336
