Why my xperia L not charging?
My device , xperia L , not charging well.....Please I need help
And I know that the problem is not the charger because it works on other devices...
First things first, take a look inside the charging port. Sometimes gently taking a toothpick plus a bit of canned air can clean out if the port has stuff in it. That alone can affect the charging rate or if it will charge at all.
If this still does not work, you may need to replace either the battery or the charging port. The charging port is a soldering job, so I would recommend iPad Rehab.
I hope this helps!
Hey rodyk28,
I think it's your charging port, because you're saying "it's not charing well".
same as my xperia l
it wont charge and get red ligh flash on bottom :(
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,026
