The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Questions View all
Why wont the cold water shut off?
The cold water keeps running after the washer starts and I don't believe that it would ever shut off. We have to stand there and turn the cold water faucet off and on during the whole washing cycle.
Add a comment
1 Answer
Chosen Solution
Most Frequent Causes for Washer overflowing
Cause 1
Water Inlet Valve
Try shutting off power to the washer. If the washer still overflows even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Cause 2
Pressure Switch
The pressure switch shuts off power to the water inlet valve when the proper water level is reached. If the pressure switch fails, the water inlet valve will continue to fill the washer tub with water, causing the washer to overflow. Before replacing the pressure switch, check the air tube to the pressure switch to ensure that it is clear of debris and is not leaking.
Cause 3
Low Water Pressure from House Supply
The water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the water inlet valve does not get enough pressure, the valve may not close fully after the power is shut off. As a result, water can leak into the washer and cause it to overflow. Check the water pressure to determine if it is sufficient.
Please give us your model number for parts identification and where to get.
Score 4
Add a comment
Add your answer
Shirley Ducklow will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 884
