Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Why does iPhone not power on?
Hi , I bought iPhone with bad battery. The phone does not charge and when is connected to a PC nothing happens . Hard reset is also not possible due to damaged home button.
I tried to replace the battery but without any changes.
Thanks for the advice .
Add a comment
1 Answer
Chosen Solution
I would replace the dock port, since you said home button doesn't work it is likely that the dock port is damaged and causing the phone not to charge. Also try booting with the camera flex removed.
9 Comments:
I tried to replace the battery with a new one and new battery Would should have some energy , right ?
by
Does the battery have a charge? (Check with a multimeter) If it does then try to power on with only the screen power flex and battery, no dock port
by
Thanks for your advice , I tried to use old battery and the phone is switched on , but after 4-5 minutes always restarts . With the new battery will not turn on .
by
That indicates a charging problem, replace the dock connector first, they are cheap, and then see if it gets fixed
by
But the phone with old battery is charging and recognizing by iTunes.
by
Show 4 more comments
Add a comment
Add your answer
vasekopacalek2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 128
