Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
After replacing LCD and Digitizer, my screen is still black?
I bought a new LCD and Digitizer for my iphone 3G. After replacing them both, my screen will not turn on. I know the phone works because it makes sound when I plug it in, and it registers with itunes. Also, I connected a friend's front panel to mine, and it worked. Did I do something wrong during my installation? All the connectors are securely in place. Any suggestions?
Score -1
1 Comment
It does not work after a hard reset. It is definitely the right part. Wondering, is it possible to blow an LCD? If the phone was charged when I installed the new LCD, could that be the issue?
by
Add a comment
Chosen Solution
it may just need a simple reset- hold power and home for 10seconds
try putting your new screen in your friends...if it doesn't work then you'll know where the problem lies.
is it the right part ? 3g and 3gs are not interchangeable screens
Add a comment
Yes try putting the Iphone in recovery mode using recboot, and exit recovery mode using recboot.
Add a comment
Add your answer
Mandy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,502
