Sim card is stuck inside with no tray
My phone turned off at almost full battery. So i tried to see if it was something with the sim card. I took it out to look over it and check it out. i was putting it back in and i moved to fast and it fell in with out the tray.
I have used small craft tweezers and I also tried using i needle and tooth pick. Any help is useful as i would not be able to get a new one at the moment.
Thank you
Add a comment
Dear friend
I had read ur question about issue
check this video it will help you (if no warranty)
be careful
good luck
Add a comment
First of all a sim card shouldn't be causing your phone to reboot, I am more of a PC guy so I could be wrong here (I did do a quick Google search for that and corresponding results were only of unlocked or used phones, did you buy your phone new?).
Anyway you should probably try to open the phone, should be the easiest. Or you could go to a small phone repair shop, the kind where you actually talk to the technician and don't have to leave the phone there before someone even takes a look at it, they would probably get it out for free, especially if you are going to have them check out what's wrong with the phone.
Hope this helps!
Add a comment
Add your answer
Elizabeth Griffis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 317
