ethernet port flap broken. how to fix it?
As my ethernet cable got stuck in to the port. In order to get it out i applied some great force and eventually it broken.... and now the cable is not able to stay connected and falls off... how to fix that flap?
Add a comment
Most Helpful Answer
@arpit if you are talking about the "flap" on the cable, there is not much you can do about it. Either replace the RJ45 connector or replace the cable. You'll find some great instruction about how to replace the connector on here
Score 1
3 Comments:
No I am talking about the flap present on the port of laptop
by
@arpit there should not be any flaps in the famels part of that connector. The flap from the cable fits into an opening in the famlea connector. To remove the cable you depress the flap and remove it. there are no flaps in that end. If your connector is broken, You will have to use some soldering skills to replace it since it is soldered to the board. What will even tougher is to scrounge a new port.
by
On some thin laptops, there's also a flap on the female RJ45, this permits to include this port despite the thickness of the laptop. It reproduces a part of the shape of the port.
Mine is broken too, I tried to fix it many times but now it's really broken, I'm using adhesive but it's really unconvenient so I'm also searching a good solution...
by
Add a comment
Asus K551L has a spring loaded flap on the RJ45 port. It’s hinged with plastic pins, thinner of them (the one that has the spring) was broken on mine.
I grabbed a paper clip, straightened one end, heated it up with a lighter and pressed into the plastic where the plastic pin had broken off. Then just cut off the rest of the paper clip and you have a metal pin. Put the spring back (longer leg goes into the laptops underside, a small hole in the bottom corner) and shorter leg has a visible hole on the flap itself.
Score 1
1 Comment:
I really wish you would have attached pictures. Sounds so phenomenal as a solution but I'm really having difficulty wrapping my head around the how and the what...
by
Add a comment
its the spring door where you pull it down and it has a notch for the nework cable can flow thru and it closes on the jack head holding it in,,, mine is gone and im trying to make one with my 3d printer... i needed to put the network cable in and i used vice grips and held it in for a few hours to trouble shoot my stupid wifi..
Add a comment
Add your answer
Arpit will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 45
All Time: 11,010
