Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Fan connector glued to the motherboard?
http://www.l2order.com/pictures/1820_L3....
It's this part. It's attached to the fan itself but it isn't attached to the motherboard.
If I press down the connector to the motherboard the fan works, but my question is could i glue it to the motherboard? And If I would, I would save 40 bucks but I'm not sure whether the glue could damage the motherboard itself
Score 1
Add a comment
1 Answer
Chosen Solution
When you press down the metal contacts are completed thus enabling electrical flow. If you can clamp it down so that connections are made then use very small amount of glue to hold the edges in place you might be able to get it work.
Here are some other excellent solutions: I popped off the fan connection from the logic board...Fix?
Score 1
Add a comment
Add your answer
Albertas Ensteinas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 959
