Check engine light came on
Had it diagnose and the code P0451 pressure sensor switch read is that a easy fix where can I find the sensor and should I still be driving I checked my gas cap oil and radiator fluid and it's all well can anyone help me out
Add a comment
1 Answer
Most Helpful Answer
@slop3 P0451 indicates the EVAP pressure sensor is faulty or the EVAP system has a leak. It is not the sensor that is at fault but you do want to check these things:"
Defective Fuel Tank Sending Unit
Defective or damaged Fuel Tank
Defective Fuel Tank Pressure Sensor, wiring, or computer
Defective Carbon Canister
Defective Canister Vent Valve - in some cases
Here is the typical KIA EVAP components. Anyone of those could in theory cause this code from popping up.
Score 1
Add a comment
Add your answer
Rene will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,192
