Why is my ASUS laptop sound not working
the sound will not work
You may face sound problem due to several reasons listed below.
First of all, you need to add an external speakers into your computer and then try to play an audio file, let’s see if you can get the sound from your computer or not.
Did you check the mute function? you might not be getting audio from your computer just because you have muted it by mistake. so do not forget to double check it. Also try to update the audio driver. for more information, you may visit: asus laptop sound not working.
Hello,
Sometimes the issue appears because the sound driver crash, so you can install the latest driver from manufacturer web site.
Or May be if you open you laptop for some hardware replacement, you forgot to reconnect the sound connector to the motherboard.
Regards
You might be facing audio problem due to the speakers problem. So you need to go ahead and replace the speakers or use an external speakers once again. for more details: how to fix asus laptop sound not working
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,084
