Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Power button cycling and volume down not working, otherwise seems fine
Yesterday, some coffee spilled into a tray in which my iphone6 was placed. The power button was inoperable when pressed, ie physically/mechanically , but began acting like it was being pressed sporadically (so I could not fully turn it off because if I turned it off via accessibility setting it would turn right back on). The frequency of the "pressing" increased as the day went on (again, not physically, just electronically). The volume down button also did not work. Otherwise, the phone was fine. Eventually, the battery died and it is now in a bag of rice. Any diagnostic and/or repair suggestions? Thx in advance.
Add a comment
1 Answer
you need to get the phone in to a repair store and have them run it through their water treatment program. the rice will not be successful in pulling all the water out of the phone. The water is corroding all the electronic connectors as we speak. That is what is causing your various buttons to fail. Time is of the essence. The longer you wait, the more buttons will fail and ultimately the entire phone.
Score -1
2 Comments:
"water treatment program"? It's the water that kills your phone, that's why it's called water damage. You need to clean all the innards of the phone with rubbing alcohol except the battery and the LCD assembly. Take it out of the rice asap. P.S. The rubbing alcohol has to be at least 90%
by
sorry - should have been more clear. most repair stores have a program to treat phones that have water damage. rubbing alcohol is a good start but for best results place it a bath of 94% rubbing alcohol with a multi-variant frequency cleaner (a jewelry cleaner on steroids).
by
Add a comment
Add your answer
AB Har will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 68
