Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Does an iPhone 6+ screen works without home button flex cable
Hi,
I replaced the screen of my iPhone 6 plus. Now the flex cable of the home button in torn and i have got an instant black screen and no response at all. I was wondering if i broken my iPhone or i just have to replace the home button flex cable on the back of the metal plate? (it did work first, but because my ear speaker wasn't working i reopened it and then i destroyed the cable for the homebutton)
thanks in advance,
Add a comment
1 Answer
Chosen Solution
No, you're phone should work just fine. Your Touch ID will never work again. But your phone should work just fine, also you can replace the button with an aftermarket one. Or you could just use assistive touch
iPhone 6 Plus Home Button Assembly Replacement
iPhone 6 and 6 Plus Home Button Assembly
If your phone is off, hook it up to iTunes. To see if it's still working fine. Should be. If it stays "black screen" either your display is broken, or you need to do a force restart
How to Force Restart an iPhone 5
I realize the guide is for the iPhone 5, I assure you the principle is the same
iPhone 6 and 6 Plus Home Button Assembly Image
Product
$19.99
iPhone 6 Plus Home Button Assembly Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
iPhone 5 Image
Guide
Difficulty:
Very easy
30 seconds
Score 4
2 Comments:
So there is no change i screwed the connectors attached to the motherboard? i think i just have to buy another screen then
by
Sounds like it. Unless you have a display you can test, to rule that out
by
Add a comment
Add your answer
iPhone56783 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 3,233
