Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
iPhone backcase change, missing screw hole.
Hi.
I have got one of the chinise backcase copies without this screw hole at step 23: iPhone 3GS Rear Panel Replacement
what can I do to fix it?
/ Robin
Add a comment
Most Helpful Answer
I've run into this. Either use a very fine drill bit to drill the hole. Or use the screw itself to drill the hole, it will take some time of screw rotation and pressure.
Score 1
Add a comment
I have the same issue. What is the proper way to install the screw hole and thread of a 0.9 millimeter screw?
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,661
