Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
How Can I Remove Stripped Screws from the Edge of 6s Screen?
Hello,
I am replacing the screen on a previosuly water damaged 6s that I have thoroughly cleaned out, and I cannot get the screws off the back plate of the screen, apart from 2... 4 are rusted in. What can I do to get them out? Thanks...
Add a comment
1 Answer
Chosen Solution
Are they the holding the backing plate on the sides of the screen? only option is to use a screw extractor or drill them out then replace
4 Comments:
You can also possibly try a torx bit as well or a flathead, I managed to get a stripped logic board screw out by using the torx bit you would usually use on the bottom screws
by
Thanks, where can I fix screw extractors small enough for an iphone? heh
by
Hello? Id like to know where I can find them I honestly ant find anything...
by
Just drill them out with a drill bit as big as the head of the screw
by
Add a comment
Add your answer
ZsTech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 119
