Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5S - won't turn on without 'hard reset' but works perfect
Hi
I have a strange issue, I have an iPhone 5S with signs of water damage.
I have replaced the battery and screen,
The device in general works fine until the battery goes flat, or it is turned off.
When I turn it back on, the display does not light up at all although the phone is recognised normally in iTunes.
When I hold down both buttons it will boot up fine and work flawlessly.
The phone does not vibrate when I attempt to turn it back on so I believe although the phone is recognised fine by itunes it does not successfully boot fully until I hard reset it...
The phone otherwise works fine and I have restored it via DFU mode
Add a comment
1 Answer
It will sometimes turn on normally after turning it off.
Just then the battery went "flat" even though it shows 59% on reboot.
Do you think it is a Power IC chip issue?
Add a comment
Add your answer
Brick50 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 6
All Time: 64
