MacBook Pro Mid 2012 No Backlight
I have a Macbook Pro, serial ending in F5WV, that was purchased refurb from apple for a employee to use. It last about 6 months until it was brought back to me for having no display. I did some digging and I have come to the conclusion that the backlight is the issue.
-I can do the flashlight trick and see my apple logo and users etc.....
-I can hook it to an external monitor and have it work perfect.
-I get a tiny little flash every time i boot but other than that the screen shows no life unless the flashlight is held up behind it
I have located the fuse and the driver but when i go to check the fuse the board shorts and cuts off. Obviously i am not finding the correct ground.
Any help with this issue would be GREATLY appreciated!! Even if its just helping track it down to the fuse or the driver!
2 Comments
@tylerh It should not short out or cut off when you check the fuse. Mark the fuse on one of your images. What 820-XXXX is your board? How did you check the fuse? Why do you have the computer on to check it?
by oldturkey03
@tylerh any news on this? I have the exact same problem! I don't even know how to "check" the fuse or where is it... OldTurkey03 is helping me too hopefully. Thanx
by Alex
