Exchange hdd for a new ssd disk. Can I use this?
May I use this in my iMac? ;
https://www.kingston.com/en/ssd/consumer...
Will it work out of the box? Do I only need a 2,5 - 3,5" adaptor?
Thanks all :D
Thanks all :D
Instead of swapping out your HD for a SSD why don't you just add it as a second drive. This series has a spare SATA port! Follow this IFIXIT guide: Installing iMac Intel 27" EMC 2390 Dual Hard Drive Kit and heres the full kit you'll need: iMac Intel 27" Mid 2010 Dual Hard Drive Kit you still need the SSD drive. Make sure the SSD you get is able to run at SATA II (3.0 Gb/s) as that is what the system requires for any drive you put in.
Another option here is to swap out your current HD for a hybrid drive (SSHD) which has the deep storage of a traditional HD and the speed of a SSD in one device. This is the drive you want: Seagate SSHD
If you do go with a HD to SSD swap out you do have to adapt the 2.5" drive to fit the 3.5" frame you'll need this: OWC 2.5" to 3.5" Drive Adapter Bracket
For either you'll need to supply a replacement thermal sensor for the system to manage the fans correctly, you'll need this: OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade
Here's the IFIXIT guide you'll need to follow for either: iMac Intel 27" EMC 2390 Hard Drive Replacement|iMac Intel 27" EMC 2390 Hard Drive Replacement]
Product
$27.99
Guide
Difficulty:
Moderate
40 minutes - 2 hours
Guide
Difficulty:
Difficult
1 - 2 hours
Thank you Dan ! :)
Is the SSHD you linked to backwards compatible with 3.0 GB/S ?
The reason of exchanging the disk is that the one I have now is not working.
Yes! The Seagate SSHD is compatible. It offers SATA I/O port sense technology so it matches the systems SATA port speed. Here's the Spec sheet: SSHD spec sheet here you'll see the line SATA Transfer Rates Supported (Gb/s) with 3.0 Gb/s listed.
For comparisons here's Western Digitals SSHD offering: WD Blue SSHD spec sheet note how this is a Fixed SATA III (6.0 Gb/s) drive which would not work in your system.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
