Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
LCD screen is blank on 6 Plus
I've replaced a lot of iPhone screens and just replaced an iPhone 6 Plus screen. After resetting it everything worked properly so I screwed down the bracket. When I went to close the screen I noticed it was blank. I hooked it up to the computer and the touch screen is responsive, just not the LCD. What could be my issue? I've tried two other screens and neither of them will work either.
Score 1
2 Comments
Is there an image , but no backlight? The image would obviously be very faint with a flashlight against it. And of course you would know which screws go where.
by
Nope, no image.
by
Add a comment
Most Helpful Answer
Here is a guide for you: Why iPhone Won't Turn on after Screen Replacement
Score 1
Add a comment
I fixed it. I unplugged the battery and cleaned the connectors with 99% isopropyl alcohol, dried, and gently reconnected it all. Everything works now :)
Edit: I got up this morning and tried it out and now it won't work again :(
Score 1
Add a comment
I think it's time to send it to a microsoldering professional. It isn't the backlight filters, because then it would have some kind of image with a light shining on the screen just right. I would guess that it has something to do with the 1.8 volt line on pin 29 of the lcd connector. I could very easily be wrong about that though.
Score 1
2 Comments:
I concur. I am sending one board out at the first of the week and am sending this phone in with it.
by
Good choice. Let us know what the problem was when you get it back.
by
Add a comment
Could also be that one of the pins bent or broke on the phone itself in the connection on the logic board. Check the pins where the display cables connect to.
Add a comment
Add your answer
justin epley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 353
