A 12.2-inch "prosumer" tablet released in February 2014. Powered by a custom version of Android 4.4 KitKat.
40 Questions View all
Crack on side of Note Pro 12.2. Advice would be appreciated.
Hey there! I would greatly appreciate anyone's advice.
I discovered today that my Note Pro 12.2 had cracked at a point around the sides of the device, where the S Pen slot is (photos attached).
I only noticed the crack today, as I was putting the tablet into my new Logitech Pro keyboard case that I just bought. How I managed to crack the tablet, I'm not sure (I haven't dropped it before). I'm presuming it's something I did as I slid the tablet into the new case. I'm surprised however, as I was never rough with tablet. The tablet still functions perfectly.
So I was wondering if anyone knew if this is repairable? If so, would it be worth repairing tablet? I have no idea if cracks like this get worse over time. Hope that makes sense.
Thank you. Advice would be appreciated :)
Photos
http://imgur.com/a/IxuJO
Add a comment
1 Answer
Most Helpful Answer
Given that you've got it in a case, it likely will not get worse over time unless you are regularly straining it by removing it and replacing it in the case.
I would certainly keep an eye on it anyway. If it does shift to a point where debris can get in under that screen, I'd be concerned, but as of right now, I wouldn't advise a repair, as the risks during repair outweigh the reward of having a flawless frame.
Score 1
1 Comment:
Thank you for your response! Yes, I will leave the crack alone for now, and check if it gets any worse over time. I do hope that there is a possibility the frame can be fixed, if the crack does become a problem. Thanks!
by
Add a comment
Add your answer
Trist will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 102
