1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Questions View all
Why is battery draining so fast?
This MBA has a replacement battery in it, I am not sure where it was purchased but it says it is a TOP. Using Cocoanut battery, it shows it is two years out but still at peak capacity. But when the computer is unplugged, the battery drains in a matter of 20-30 minutes... but then when plugged back in will recharge in about that same period of time. Does this indicate a bad battery? Or something else? Thanks.
Add a comment
1 Answer
Chosen Solution
Have you tried resetting the SMC? Here's how: Reset the System Management Controller (SMC) on your Mac.
The next thing I would do is see if restoring the battery helps. Here's a good writeup on how: How to Restore and Charge MacBook Batteries
You also you might want to check the batteries firmware: Battery Update 1.2
Score 4
Add a comment
Add your answer
jmoravec will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 14,345
