Can I fix a whiting out screen?
In April, I received an LG441G as part of TracFone's 2G network shutdown replacement offer. Last week, without apparent cause (dropping the phone, etc.), some white horizontal lines appeared near the top of the screen; there don't appear to be many or any more lines like that, but it's hard to tell. The problem has worsened through the screen getting too bright to read, inconsistently. Sometimes it's mostly clear when the phone is turned on, other times it's completely white and dims later. Sometimes it flickers, though I'm not sure it's doing that any more. Everything else on the phone seems to work fine still, as far as I can tell, and the screen does still go to sleep.
I looked on iFixt soon after discovering the problem, but, finding that there was no entry for this device, I wrote LG. LG told me to talk to TracFone. TracFone apparently doesn't have an email address, just a link claiming to lead to one, so I called them. They said that they only offer a replacement, not a repair, and that I'd have to call from another phone to get it set up (which I don't have and would have to borrow somewhere). That seems quite a bit of bother for what may well just be a loose connector, and so here I am.
Any ideas? I'm hesitant to just go poking around inside without knowing what I'm doing, since, if I do have to get it replaced, I'd like to take advantage of the warranty.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
ohinds8 since this is covered under warranty, you definitely do not want to mess with it. It sounds like more than a loose connector. Sounds more like a bad LCD or a bad video circuitry. Repalce your phone under warranty to avoid any further surprises
Score 1
Comments:
Ah well. I'd prefer to be able to just fix it here, but you are probably right. Thanks!
by
Add a comment
Add your answer
ohinds8 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 120
