Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
709 Questions View all
iMac doesn't boot. Only left LED on Logic Board is lit
My Mid 2011 27" iMac EMC 2429 will not boot. The display doesn't come on, out of the 4 LED's on the Logic Board, only the 1st LED lights up, the other three are not.
My question is, I know it's not the PSU because the Logic board recognizes that it's getting power. Could it potentially be a failed Logic Board? and what does it cost to get it replaced?
Upon further inspection:
Removal of LCD screen. When powering on, there is some noise of noise activity from the PSU. No other activity seen or heard from other components. Upon holding the power button for 5 seconds, sequencing a hard shut down of the system; the noise level of the PSU drops from a 5 to a subtle 2. Upon further inspection of the PSU, there is an white-ish discoloration around the border of the unit (shown in pictures).The middle of the unit, excluding the border has a glossy, almost oily presentation.
Upon testing voltage of Pin 11, we have a 12.01V reading on the voltmeter.
No voltage reading from Pin 4.
Coin battery voltage measures at 3.0V.
Score 2
Add a comment
Most Helpful Answer
Incorrect logic, all you know is that the power supply is getting trickle power.
Start with the power supply.
LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Score 3
9 Comments:
Can you elaborate "Start with the power supply?"
by
Read what the #1 LED being on indicates. Then here's the guide for replacing the power supply:
iMac Intel 27" EMC 2429 Power Supply Replacement
You'll need one of the following Apple power supplies (all will work)
Apple Part #: 661-5310, 661-5468, 661-5972
This one has a lifetime warranty: iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply
by
I updated the post with some more information.
by
Order in a power supply, install it. If it fixes the problem, you're in business. If not return it. It certainly looks like it has had some trauma. Power supplies can also partially fail. I've seen just the power to the hard drive fail or the hard drive work and the power to the logic board fail.
On this machine the most common failure was the GPU, thus this recall:
https://support.apple.com/en-us/HT203787
by
Does iFixit allow returns if the item has been installed?
by
Show 4 more comments
Add a comment
I'm curious how this worked out. I am in a similar situation. I'm prepared to buy the power supply (have it in my cart now) but worried it's not the fix. I too have only the first LED lit, but I have no sound whatsoever.
2 Comments:
Hey. I'm the original poster here. I purchased the power supply, installed it, and nothing changed. Went ahead and returned the power supply unit for $10 shipping back and a restocking fee.
Went ahead and just sold my iMac as is. Didn't have the time or money to keep trying to fix it.
Sorry for the late reply.
by
I also purchased the power supply, installed it, and nothing changed. Debating my options now.
by
Add a comment
Add your answer
Benjamin Luman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 1,611
