Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1010 Questions View all
16GB 1600mhz vs 16GB 1866mhz RAM for MacBook Pro 13" mid 2012
I ran Geek Bench to test on 2 types of RAM's on my  13" MacBook Pro 2.9 GHz i7 (mid 2012).
1 - Crucial 16GB Kit (8GBx2) DDR3L-1600 SODIMM
32bit test: 2913
  • Single-Core Score: 2913
  • Multi-Core Score: 6105
64 bit test:
  • Single-Core Score: 3132
  • Multi-Core Score: 6754
2 - Kingston HyperX Impact Black 8GB 1866MHz DDR3L Laptop RAM (Low Voltage - HX318LS11IB/8)
32bit test:
  • Single-Core Score: 2715
  • Multi-Core Score: 5814
64bit test:
  • Single-Core Score: 2986
  • Multi-Core Score: 6975
So I would like to know your opinion about RAM. Which is better for my MacBook Pro:
Comments:
Just to be clear here your second set of tests with the Kingston HyperX Impact Black was also two 8 GB modules. Correct? (both tests was with 16 GB of RAM)
by
-------------------- Crucial Vs Kingston
32bit test:
Single-Core Score: 2913 ---- 2715 - Diff of 198
Multi-Core Score: 6105 ---- 5814 - Diff of 291
*** Crucial is faster, but by very little
64bit test:
Single-Core Score: 3132 ---- 2986 - Diff of 146 to Crucial
Multi-Core Score: 6754 ---- 6975 - Diff of 221 to Kingston
*** Equal in performance as each bets the other.
by
Add a comment
1 Answer
Chosen Solution
First with any test like this you need to know what your OS and the apps are running at. In this case the newer versions of OS-X are full 64bit and the applications are generally 64bit as well (with rare exception).
In this case the performance difference between the manufactures is very little under 32bit but it makes little difference here as we're running 64bit. Under 64bit test the difference is even less! So I would focus on what costs less here.
The problem you're facing is the systems memory bus is running at 1600 MHz so the faster 1866 MHz memory is not offering any benefit here.
Score 2
Add a comment
Add your answer
khaidir77 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 70
All Time: 1,588
