Why won't my laptop turn on?
My laptop was on and then it suddenly went off.
When I press the power button it flashes 5 time but doesn't power up, the charging light doesn't come on when plugged in.
Any help on how to fix this problem would be great thank you.
1 Comment:
Check the LED on your charger if it is flickering or if it makes any noise when "charging" as there is a possibility the charger to be damaged and not the laptop.
by
Add a comment
1 Answer
Have you tried wiping off the battery contacts with alcohol? How about your charger /adaptor if all trhee are good then your last chance will be the battery do you remember dropping it? When a battery falls a lot of rimes will get ruined, hope i was of help
Add a comment
Add your answer
Izzi Hotson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 233
