Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Question about screen replacement.
So I'm going to change the screen on my 6 plus, but when I got the phone, the screen was very badly damaged and I can't see anything on the screen. I can't power down the device because the screen is so bad, and doing a hard reset doesn't seem to be doing anything. When I press the power button a couple of time, the screen will light up with a few lines on it, then go dark. I've been trying to get it to die now for a week, but I can't tell if it's totally dead. Can I just disconnect the battery and do the screen replacement, or do I need to be positive that the phone is dead and powered down? Any help would be much appreciated. I don't want to cause any extra damage. Thanks.
2 Comments
You can pull the battery. I pull the battery on every repair I do and I have absolutely no issues. I've fixed over 1000 iPhones.
by
Without powering down the device first?
by
Add a comment
Chosen Solution
you can unplug the battery without powering down the phone. don't use any metal spudgers to disconnect the battery. its best to power down and definitely disconnect battery before working on your phone. press the power button several times after disconnecting battery to get rid of any power left on device.
Score 2
Add a comment
Well, looks like it's time to send it off for a replacement, either screen or device.
2 Comments:
?? You didn't answer my question. Can I just unplug the battery, or do I need to make sure the phone is dead first?
by
Make sure the phone is dead first
by
Add a comment
Add your answer
michaelwall82 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 135
