Lid light error comes on and lid won't lock.
The lid will not lock and a 'LID" error message keeps coming on. Is there a way to fix this that doesn't require tools or a large check?
The door lock, also known as the interlock, is a safety mechanism used on front load washing machines and on some top load washers that prevents the door or lid from being opened while the machine is in operation. The system consists of a door mounted catch and a door lock mechanism located on the back of the front panel/door shroud or main top. The lock mechanism consists of some switches and normally a lock/unlock solenoid or wax motor solenoid. When the cycle is started, the washer control will activate the lock solenoid/wax motor to prevent the door or lid from being opened. At the conclusion of the cycle, the control will activate the door unlock solenoid or will deactivate the door lock wax motor. The wax motor style of solenoid normally takes at least a minute or two to activate or deactivate. If the door or lid won’t open at the end of the cycle, then the lock mechanism may be at fault. Most washers will have a manual release to unlock the mechanism and allow you to open the door or lid. The release is normally accessible from below the door lock, or on some models, from inside the soap dispenser housing.
Some models will have a digital display that will show a fault code in addition to the door or lid not opening. Once the door or lid has been opened you can then access the door lock assembly to check for a defect. On front load washers, you will need to either raise the main top or remove the front panel to gain access. Check for signs of a solenoid or wax motor overheating or a mechanical defect in the assembly. You can also check the door lock switches and the solenoids for continuity with a multi-meter and replace any that are found defective, however most door lock mechanisms are available only as an assembly. On top load washers you will need to raise the main top to gain access to the door lock mechanism. Remove power from the appliance before attempting service and never bypass a door lock safety mechanism.
How to open top lid on MayTag Bravo Washer 300 series
Unplug washer and replug to reset worked for me
Is there a way to bipass this? I hate Maytag products. First and last time I order.
Im not THE parent eho will wash my kid with my clothes. My lock won’t eork so neither will my washer which I think is asinine. I want to do a wash, how can I bypass this lock ? Is there a wire I can cut to disingage it?
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 7,914
2 Comments
the answer didn't even attempt to answer the question that was asked. the problem is that the lid will not lock, not that the lid won't come unlocked.
by anunusualwoman
@anunusualwoman Sorry ? what are u replying at exactly ? How about asking a question yourself if you have a problem you need help with..
by arbaman
