TV shows vertical color lines
Hi
I got a Panasonic 50 inch LED UHD 4K TV model TH-50CX700A. I bought it from gumtree ( so no warranty) just 3 weeks back. First 2 weeks it ran like dream. Now it shows vertical color lines when turned on. Strangely sometimes it comes back if I UNPLUG it from power source and keep it like that for sometimes, plug on again then it runs perfect! But if I keep it on standby mode, and turn it on, the green indicator light blinks like 7-8 times and red vertical lines appear. Whats happening?
Score 1
Add a comment
Chosen Solution
@mirehsan The blink code are as follows
6 blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
common error on those models is the SC board. I'd definitely start with that.
Post some images of what your screen shows as well as your boards etc. That way we can see what you see. Use this guide for that.
Score 3
3 Comments:
@oldturkey03 Thanks for your valuable input. I have uploaded picture just now. Would be grateful if you could advise me what I can do now.
by
@mirehsan not sure where you uploaded your pictures:-) Follow the guide referred to in my answer to add images to your question.
by
@oldturkey03 I think its visible now. thx
by
Add a comment
Hi was this an easy fix as my Panasonic is doing exactly the same , thanks
Add a comment
Add your answer
Mir will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 3,476
