How do I fix?
have new battery. Only small G in right corner on screen.
If all you want to do is replace the battery on your calculator
Replace the battery by following the steps below:
• Remove slide cover and place the calculator face down.
• Using a small screwdriver, remove screws from the back case.
• Starting from the bottom, carefully separate front from back.
• If necessary, use a small Phillips screwdriver to remove the old battery and insert a new one.
• Place the back case on the unit and replace the screws.
The TI-30X should function properly once the ON key is pressed.
Cautions:
Be careful not to damage any internal parts.
Avoid contact with components while changing the battery.
Hope this helps
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 94
