4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1050 Questions View all
iPhone SE water damage no service
Hello all,
So my iphone was submerged in a lake for about 2 minutes after my boat flipped. After leaving it in rice for approximately 4 days, I powered it on and found that most functions seem to work. I still have some slight water mark at the top of the screen, but more importantly I get no service on the cell network. If I connect to wifi everything seems to work and I can make calls and get texts via wifi.
Does it sound plausible that the data antenna is fried and I can just replace that component? I can't seem to find an SE logic board anywhere on the internet, so I'm not looking forward to that being my problem.
Regards,
Jordan
Add a comment
1 Answer
Most Helpful Answer
I would not put my phone in rice if I dropped it in water. By putting it in a bag, you are essentially drying the water already, as for the rice it may pull some moisture from the phone, but you will end up getting rice residue inside the phone.
Regardless of the drying method used, you never want to dry the phone with water still inside, need to clean it first. Water leaves behind mineral deposits, which can also conduct electricity just like water. Essentially, if you turn it on without first cleaning it, you run the risk of short circuiting the phone.
1st Step: The best thing to do at this point and in case it ever should happen again in the future, is to remove the logic board and wash with 99% Iso Alcohol and lightly clean with an ESD safe brush, you can get it from the iFixit store online. Then let the board dry in a zip lock bag with some silica bags (the bags that come in shoes boxes and such). Then reassemble and check again.
*Sorry for all the extra text, but it's easier to clean the board up, because water residue can mess with the connectors and the "chips" on the board, which can affect your signal.
2nd Step: Change out the charging port (clean the frame under the charging port with alcohol first) to see if that will work. The iPhone 5S charging port is different, so make sure to use one from an SE. Then reassemble and check again.
3rd step: Likely to be one of several ICs on the board. Need to send to a Board Level Repair Specialist, unless you have a decent microscope, soldering tools and lot's of time and patience. If you have those, you can find videos on Youtube - iPad Rehad has videos of a bunch of different issues. Good start.
Score 1
Add a comment
Add your answer
jordan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,618
