Repair Guides for HP Desktops.
355 Questions View all
does this site handle this PC
PC HP a6414f (not listed as your a6500 .
can I get repair, etc info here?
Update (05/26/2016)
"ERROR:SYSTEM FAN has failed! Service PC to prevent damage to the system. Press <f2> to continue.
  • on my third day of this, having hit f2 twice on the last two days and using the PC as usual, I opened the case side panel, confirmed all fans were operating and blowing air.
Once getting onto my browser FireFox (ver.43) and IE (ver. loaded on Jul 2008) opens to : X Couldn't load
XPCOM.
So am forced to use Google Chrome to access internet.
Score 1
2 Comments:
What exactly are you having an issue with? I can try and help...
by
What's the issue? What happen when you turn on the pc?
by
Add a comment
1 Answer
Could be a number of things:
Error Message Issue:
If your running Windows XP, your going to have issues because Windows XP hasn't been supported since 2014...This means that your not going to be able to update the Operating System. This would include the update to Explorer that was loaded in 2008. Your version of Firefox and IE is old and that is why your getting the error message "Couldn't Load XPCOM", You need to update it to the current version, The Current Version of Forefox is 46.0.1. If your going to get online with this Machine and want to avoid headaches, You will have to Upgrade it to Windows 7.
System Fan Error Issue:
- Pull BIOS battery, wait for 10 seconds then replace. (you may get a message during boot that says the system time is wrong) you can just hit F2 and fix your time in the Operating System.
- Try a hard reset- Turn off the PC/ Unplug it from the wall/ Press Power Button For 10 Seconds/ Plug PC back in/ Turn on PC.
Hope this helps...
Add a comment
Add your answer
Bike Mann will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 98
