The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Home button not working after battery change
Home button no longer operating after I replaced battery. Can I replace it? or is there something else happening?
Add a comment
1 Answer
Chosen Solution
Is the home button jammed? If yes attempt to reseat the home button and the iPad Digitizer / glass.
Is it not working at all? Check if the two golden push pin connector points near the charging point are not damaged or bent.
If you didn't take the home button off the glass at all then I really doubt the home button itself is faulty.
You most likely damaged the two golden push pin things above the charger port and will probably need to replace the charging port because I'm pretty sure it goes together with the two gold push pin things.
Score 2
Add a comment
Add your answer
blnfrd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 80
