Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Battery problem? (Percentage issue)
I have an iPhone 6 bought in 12/2014 and in March this year started to have some problems related to the percentage of the battery when it is near 20/25%, the phone turns off and says "no battery" but if I try to power on, fifth/sixth attempt later, boot with is 20/25% usually, sometimes the battery jumps from 25% to 10% and stuck on that until the battery really reach 10% when I connect the charger the percentage back to their normal, it all started when I upgraded my iPhone from iOS 9.0.2 to 9.2.1, I tried to clean install iOS 9.3.2 on iTunes but the problem continues ... this can be a problem in the battery or is a bug on iOS? I have less than 500 charge cycles.
Score 1
Add a comment
Chosen Solution
It shouldn't be that bad.. But then again Apple likes to do this kind of thing. I got my 6S on release date, and the charging port is already going bad. You could change your battery... I haven't heard anything about the new iOS hurting battery life..
iPhone 6 Battery
iPhone 6 Battery Replacement
iPhone 6 Battery Image
Product
iPhone 6 Battery
$29.99
Score 4
1 Comment:
Battery life is not the problem, the problem is the phone turning off with 20/30%, i think i will try replace my battery, Thanks!
by
Add a comment
found this blog http://www.etradesupply.com/blog/how-to-...
Score 1
1 Comment:
Thought connecting to wifi would auto fix that...
by
Add a comment
You can also try by using an original charger. Keep in mind that when you purchase an iPhone which is not brand new, the charger is not always an original one. So try to purchase an original iPhone charger and things would get better. If this helped you, follow me on IG @like_kyriee and i will follow back.
Regards,
Add a comment
Add your answer
Heitor Scatolin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 4,144
