Repair guides and disassembly information for Samsung's Android-based cell phones old and new, including the popular Galaxy product line. Get everything you need to repair your Samsung phone yourself.
Hang display then boot loop
Boot loop.
Samsung Galaxy S Duos 2 GT-S7582 Around 30 seconds after displaying homepage, unit suddenly hangs then max brightness triggers, a gray static screen appears, then sudden power off.. then the process repeats draining battery life.
One thing I noticed is whenever I tried to delete all messages and files from the gallery/folder, It is magically restored when the unit restarts again. Also there are some folders that cannot be deleted.
It started when we downloaded a movie and a subtitle online.
I've tried doing hard-resets and factory resets but no luck.
There's also an error on wiping cache.
Nearest technician tried to use Odin software to reprogram unit and still the problem exists.
Please help! Thank you!
Score 1
1 Comment:
What is the error you receive upon wiping. Also what version of Android. Please also indicate if it is stock from carrier or a custom rom
by
Add a comment
if odin could not fix this then i suspect the phone to be a replica (chines version) it will show a successful restore by odin but will see nothing change in the system.. if the phone is original then i suggest you re-flash using Kies instead of odin or better still us a good custom ROM available you can check xdadeveloper
Add a comment
The network is not working
Add a comment
Add your answer
jaymejorrol will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 632
