Can I use an ATX PSU for it?
Defective PSU for ITX Gigabyte motherboard GA M61PME S2P, and I aim to replace with ATX PSU; first of course, by transferring the motherboard to an ATX case. I hope for help regarding compatibility issues. Thanks.
Add a comment
1 Answer
Chosen Solution
As long as there are enough watts in the power supply, you have a case that can fit an ATX power supply, and you have the right CPU header (4 or 8 pin) you should be good...
The only thing I think you may have a problem with is not all ATX power supplys have 4 pin CPU power and that motherboard has a 4 pin CPU header...
Score 1
1 Comment:
Thanks. That is really reassuring.
by
Add a comment
Add your answer
Sapsap Wap will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 496
