Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Horizontal Black Lines On Screen
I recently bought an iPhone 5c off of a friend. Seemed to work perfectly except for the top right corner was a little out of place. Suddenly I was getting dim flickering lines across the screen. It also seems that the screen is a lot less bright. I figured out that if I apply pressure to the top right hand corner of my phone, the lines would go away, but would come back once released (I tried placing tape there but it didn't help). Does anyone know of an easy fix for this issue? I tried ordering a case to see if it could permanently push in the screen, but I figured I would rather just have it fixed forever if I decided to take off the case. I really don't want to go to get my screen replaced for such a simple (or I presume) problem. I kind of figured it might have to do something with the wires connected to the LCD but I do not want to just open my phone without knowing what to do. Thanks!
~Henry
Add a comment
1 Answer
Most Helpful Answer
Don't apply pressure to the screen because it might crack the display or LCD. It sounds like something may be stopping it from laying correctly in the phone. Try removing the display and make sure all the connectors are properly seated and that there isn't anything stopping the screen from laying down.
Score 1
1 Comment:
Ok thank you I'll try that!
by
Add a comment
Add your answer
Henry will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 264
