Second version of the Beats pill. Sold by Apple in California. Released in 2013. Model number: BO513.
20 Questions View all
Why won't my pill charge?
All of a sudden my pill won't charge,I didn't drop it nor is it damaged.Can you help?
Score 3
1 Comment
The battery has 4cables in a block connected to the circuit board pull this block out of the circuit board then reconnect. I'm pretty sure mine had just vibrated loose,beats pill worked straight away and taking a charge.
by
Add a comment
Chosen Solution
Here's how to get into it. Look for the number on the battery:
https://www.youtube.com/watch?v=Jh3VWvA3...
Score 5
1 Comment:
I have met the same problem, my beats pill 2.0 won‘t charge and out of warranty. After watching this video, i bought a replacement battery from amazon and replaced it by myself, it works great. Thank you. The battery's ASIN is B01MXDCSXT, you can search it on Amazon.
by
Add a comment
most likely, the battery has gone bad.
i am searching for one myself, but its starting to seem that you have to send it back to apple for battery repair\replace..
Update (12/04/2019)
just to add a bit.. you will also need to be comfortable soldering and unsoldering the battery leads.
if you can do that, should be a fun project.
Score 3
5 Comments:
after some digging, i found that the pill takes 2 batteries and are almost the exact same size as a gopro hero 2 battery. you have to take the cover off the gopro battery to get it to fit, but it will work.
you do need to be comfortable with taking apart small parts and possibly modifying the case a tiny tiny bit to get it to fit, but it does work..
by
Does it Cost money if you send it back for a battery replacement
by
Send it and let us know if they do it for free...
by
Only if it is out of warranty
by
How much does it costs if it's out of warranty?
by
Add a comment
Add your answer
Joe Wright will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 61
All Time: 38,966
