Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Questions View all
Sometimes it boot up, Sometimes don't
My iMac sometimes boot up normally, sometimes it boot up with a dead display but i can see my teamviewer is running on this iMac and i can hear the chime. The iMac sometimes would freeze after a short while of use, if i force restart it, it will boot with black display(it's like a switch off LCD). It also freeze once, when i try start the mac, it freeze at the apple logo when booting up, the loading bar never came up just stuck with the logo for 8 hours.
When it do boot up normally, i had ran a complete system test, i get nothing from the scan, everything seems to be working. It longer boot up now and dont hear the chime, i only hear the fan spinning. There's also nothing on external display when it do boot up with teamviewer. I done absolutely nothing when it can boot up. Hence i had totally no idea what is wrong with it.
How do i go about troubleshoot this? Would it be the logic board issues?
1 Comment:
Do you have the original system installation disk? An external bootable drive?
by
Add a comment
1 Answer
I suspect it has something to do with the GPU... There should be 4 LEDs on the inside of the Mac on the motherboard, the should all light up when you are booting the computer that show hardware ok when lit, I don't remember witch order but one is the PSU, GPU, CPU, and I think ram (don't remember) if they don't all light up you have a hardware failure of that component that the LED is linked to...
Add a comment
Add your answer
cheelam1220 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 104
