Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
5c Ghost Touch Issue
I have a 5c that has a mind of it's own... sometimes. From the home screen, if I hover over an icon, close but not touching the screen, an app will activate.
This happens sporadically. Sometimes it will be fine and function normally and then, without reason, it will start randomly activating apps, bring up the keyboard and type, without touching the screen.
It appears that when it freaks out only one area of the touch screen is affected. So when I touch the upper left of the screen it seems to activate whatever is in the middle/lower right. And then without warning, everything works fine for awhile till it happens again.
I've tried 2 new screens and have the same issue. It has been fully restored and updated through iTunes and nothing changed.
I assume it is a hardware/logic board issue but not sure where to start looking.
Any ideas?
Thanks!
Brian
Score 1
Add a comment
1 Answer
Chosen Solution
First I would try cleaning the digitizer socket connector, with 90% isopropyl alcohol. Then, if that doesn't take, it's likely the socket needs to be replaced. Another option is that the touch ic, either needs to be replaced, or the solder needs to be reflowed
http://m.youtube.com/watch?v=tU44AjBpG6k
http://www.googleadservices.com/pagead/a...
Score 5
Add a comment
Add your answer
Brian Clark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 12
All Time: 671
