1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
My systems system is slow, takes time to booth, and hangs indefinitely
Macbok Air 13" Mid 2012 Repair
Whenever I put my system on it takes time to boot, usually shows the beach ball repeatedly for long when in the middle of operations. I don't know what might be the cause, I need help.
Score 1
3 Comments
How much free space do you have on your drive?
by
Total space is 121.33GB, 83.11GB Used, 37.88GB Free
by
That's getting tight! The smaller SSD drives need at least 1/3 of the space empty for swap & virtual RAM (depending on the app).
by
Add a comment
Chosen Solution
With SSD's free space is also needed so the drive evenly wears.
At this point I would recommend you create a bootable USB thumb drive so you can boot up under it to run Disk Utility - Disk First Aid. Let's see what it tells us. If you still have Mavericks run repair permissions and then repair disk.
Score 2
Add a comment
In addition to running to using the Disk Utility (which you can also run in recovery mode - hold down Command + R when powering on and wait until you see the Apple logo before releasing the keys)
I wouls also suggest doing a PRAM reset as the the System Manager table may be a little corrupted. To do this, press the Option-Command-P-R and Power button and hold until you hear the boot fanfare 3 time and then release all the keys. Your MBA will rediscover the hardware and create a new boot table.
Add a comment
Add your answer
Joseph will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 10
All Time: 169
