Johnson you need to provide more info; when you say "no power" i am assuming here that you what you meant to say is that, you don't get any display on the monitor? if the fans are running it means you DO have power supplied to the computer. I will recommend you remove the AC cable from the wall socket for a few minutes; and connect it back. There could be more going on here; make sure you have the monitor connected and that the monitor itself is plugged into a power source. give me more info on what is going on exactly and hopefully we might get you a solution.
The fan keep running no power came on
by johnsonmaurice2015
by Mark Norman
Thank you very much it back on running again
