16:9 LCD monitor with a 1600x900 resolution display.
I can barely see the screen
I can barely see the screen and adjusting it makes no difference
Score 1
Add a comment
1 Answer
Chosen Solution
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
Score 3
2 Comments:
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
by
Did you replace those?
by
Add a comment
Add your answer
shawn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 536
