Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
battery not charging, chatger's light stays green
Hello,
I have bought a new battery through IFixit and it worked fine for the first week,then i didn't use my macbook for 2 weeks. After that, i tried to charge it, but it won't.
Only turns on when the charger is conncted, there is a status bar message indicating:
condition: Replace now
battery is not charging.
I have tried to reset the SMC&PRAM and even take out the battery, but the problem still not solved.
-- MacBook Pro 13" Unibody Mid 2010
Please help!!!
Score 1
5 Comments
Please tell us the story of what ws happening with the old battery.
by
old battery was expanding"swollen" unitl i couldn't even click the trackpad.
by
No answer!!!! am I only the one who's facing this problem ?
by
There's to enough clues to work with. What does it do when you try to boot? Any sounds, lights?
by
I don't see anything up normal while booting...
by
Add a comment
1 Answer
Most Helpful Answer
Hey there! When the charge cable stays green, it typically indicates that either the I/O board or the battery is having some issues (or the battery is fully charged, but that seems unlikely). If you've already tried making sure that the battery has a good connection and checking the pins of the connection are still all there, then I would make sure that your I/O board still has a good connection. Failing that, contact out customer service, and we'll see what we can do about replacing that battery for you.
Best of luck in your repair!
Score 2
1 Comment:
Thank you for your answer, the pins are still there and I don't know how to figure if the case is the battery or the I/O. What I am sure about, is that the battery was charging after I installed it. I was thinking that since the battery is new and I left the macbook without usage for 2 weeks, than that would be the case. I tried my charger with another macbook pro"my friend's macbook", and It was working fine.
Please guide me if i can do a test to figure out the case " battery or the I/O".
I have tried lots of online solutions with no luck ! please help
by
Add a comment
Add your answer
harysi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 117
