Will turn off automatically after several minutes or seconds
Will turn on for couple of minutes and automatically turn off with no warning and is higher then 50% of battery left what's wrong with it?
Ok you want to flip it over find the fan vent...see if it clogged with dust...blow it out really good and then get a brush or something sweep it makes sure no dust inside or on the outside of vent...Ok then turn on laptop see what happens then.....and while running listen see if you hear the fan run or not..if it never comes on...and it still cuts off ..your fan may have burnt up...went bad.....that should be the problem ...good luck
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 70
