Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
My iPhone will only come on when charging
My iphone 3gs will not shut-off no mater what i do,i have tried holding the power and off button at the same time nothing.also when charging the screen is dark were you could barely see the apps,but will not change apps when i hit the home button,nothing happens.any suggestions?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Firstly try restoring in itunes, then see if you are still having the same issues. If it's still behaving strangely after that i'd crack it open and inspect for liquid damage as the faint screen is often a sign of this.
Score 1
Add a comment
Add your answer
lloyd will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 871
