The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
How to Unlock my Samsung Galaxy S7 Edge without password?
I bought a new Galaxy S7 to my son for the brithday present, I set a screen lock on the phone when testing the phone on the store, but I have lost my password, and my son can not use the new phone without password. How can I remove the password and enter the phone? Anyone who can help please?
Score 146
18 Comments
For the Samsung phone those which is locked by forgotten password or without password, you can try using the Samsung Galaxy Recovery to unlock your Samsung phones or tablets without losing data.
You can read the details from:
How to Remove Password on S7 Edge
How to Restore Lost Data on S7 Edge
by
First, launch Samsung Galaxy Recovery and you will see four functions are listed on the left column. Here, you should go to "More Tools". Then choose "Samsung Lock Screen Removal". Then...
by
good topic and useful too.
by
Prevent a seemingly unsolvable phone lock-out=here is some straightforward & common-sense advice. After you get a new device, install a micro-SD card & load all your desired apps. BEFORE YOU SET ANY LOCK PIN/PASSWORD/PATTERN-REGISTER YOUR PHONE ON A SAMSUNG ACCOUNT! Enable auto-backups of apps/themes/SMS/texts/contacts, etc, in the Samsung Account, save all media that you can to the micro-SD card (back this up too on PC), then proceed with your lock settings. Then, if you run into a situation like I did, where Google Device Manager and/or Samsung Find My Device functions for resetting the password fail, REMOVE your micro-SD card & do a FACTORY RESET. This WILL erase ALL data from your device. BUT, when you turn it on & go through the initial set-up, just log-in to your Samsung Account & click on RESTORE! YOU DON'T HAVE TO REINSTALL EVERYTHING-ALL APPS/SETTINGS/SMS/TEXTS w/PICS/CONTACTS/APPS/THEMES/WALLPAPERS/RINGTONES/CALENDARS/CLOCKS...YES, EVERYTHING, will be restored to your phone, as of the latest backup date & time!
by
Show 13 more comments
Add a comment
Chosen Solution
You do not need to download ANY third party software or even connect your phone to computer to remove any screen lock on your phone.
You will lose all data on the phone following the steps below:
You simply turn off the phone (If you are having difficulties just hold power + volume down + home to force shut down phone). Hold volume up + power button and home button. Stop holding the power button + home button + volume up button when the Samsung logo appears and/or a blue text at the top left of the screen says booting to recovery.
Once it has booted to the Android recovery use the volume up and down keys to select / highlight a option.
Select the wipe data / factory reset option and use the power button to select this option.
Edit: If it asks for a Google and or Samsung account and password, it means the device has FRP (Factory Reset Protection) lock enabled which you can bypass using the method provided here:
http://forum.gsmhosting.com/vbb/f777/uni...
You can additionally downgrade from Android 7.0/7.1.2 Nougat back to Marshmallow 6.0.1 (IIRC maybe also 6.0).
If the method linked does not work there are plenty other methods which you will need to look around for.
Score 51
25 Comments:
yeah, just reset your new Galaxy S7 Edge
by
Hi I was able to reach to the blue text, how do I select boot to recovery? And where will i find this after I factory reset my phone?
by
If you don't want to factory reset your Samsung phone, I suggest you try this tutorial to help you remove screen lock on Samsung.
by
i have done the factory reset but i didn't work. please if anybody knows let me know
by
I bought a s7edge my wife factoryreset it now cant get pass security how do i get in
by
Show 20 more comments
Add a comment
Follow the instructions below:
1 Go to the Android Device Manager from a computer.
2 Find your Galaxy S7 or Galaxy S7 Edge on the screen.
3 Enable “Lock & Erase” feature.
4 Then follow the given steps on the page to lock your phone.
5 Set a temporary password.
6 Enter the temporary password.
7 Create a new password.
Score 11
10 Comments:
What if it has a password already
by
just unlocked my phone brilliant
by
The WiFi is off and the pin is forgotten we know the password but first need to type the pin then password... How do we unlock
by
Does this work for patterns?
by
The phone has the draw password. How do you remove it if you forgot it?
by
Show 5 more comments
Add a comment
Steps:
1. Lock the device with a "secure" pattern, PIN, or password.
2. Activate the screen.
3. Press "Emergency Call".
4. Press the "ICE" button on the bottom left.
5. Hold down the physical home key for a few seconds and then release.
6. The phone's home screen will be displayed - briefly.
Score 6
3 Comments:
Actually just tapping the physical button for #5 works.
Play with this but on my Samsung S7 with Android Nougat, I got it to work. My 3 year old daughter figured it out.
by
Can u tell me how exactly coz i forgot my password
by
What do you mean by ice button? For me and my bottom left is medical information.
by
Add a comment
If you play with it enough, it will unlock. It is a combination of a timely double click of the main button in the emergency call or ICE screen.
My 1 year unlocked my phone and she definitely doesn't know the code. I was able to duplicate what she does but not 100% sure how to explain it.
I can do it now almost everytime on my phone or anyone else's Samsung Galaxy S7. My security settings are set on the pattern and my phone is T-Mobile stock and fully updated
Score 3
2 Comments:
It unlocks for a second and then goes back to the lock screen for me. OR it allows me to scroll down my notifications and I can swipe things away. But when I click settings or try to touch a notification, it goes back to the lock screen. How did you get past that?
by
Dear lord Billy, I would pay ANYTHING To unlock it without a hard reset I need that information badly!
by
Add a comment
no need to cut the previous owner finger or hold a gun on the head, Just double tap to active camera, then touch the bottom left split screen icon, close all screen appears, just close it and you are in, goto setting change what ever password or
Score 2
1 Comment:
provided that the phone was on and not after a cache vipe
by
Add a comment
As a user, (not someone posing as a helpful fellow user to sell you something) this has happened a couple of times and I've done it a couple of times. Many say it cant be done or try and sell software, calling Samsung didn't even help, they make a tkt and you have to call another dept on and on. AT&T will tell you, as well as others, the phone must be reset Not true. I needed to be sure to save data. 2 ways Device manager will do it, but after you enter a password through their locate my device screen, you cant do it again, it will show a message indicating the new password isn't needed because of the password it knows from your first attempt. If you go through Samsung's website and do find my mobile, it allows you to lock a lost phone with a 4 digit pin, not password. I've used that method twice AFTER using the previous method I mentioned on Device Manager once. you have to register your phone first. obviously. but it does work, And if you didn't register your device when bought, you can now and it works. Took me a bit to find/figure it out because of all the misleading, sales ploys, etc on the net. Hope this helps!! It drove me crazy!!!
5 minutes ago by Kelly Johnson  Edit  Delete
Score 1
3 Comments:
Kelly - what did you do after, though? I was able to get in by creating a new pin with Samsung find my mobile, but when I go to 'settings' to create a brand new pin (as the pin from Find My Mobile is temporary), it asks me for my OLD pin, which I completely forgot since I use fingerprint most of the time, which is the reason why I'm here to begin with. Which is not the pin I just set up through Samsung find my mobile! Now what?
by
I'm in the same situation- don't ever use my pin - only my fingerprint, so now what (other than hopefully deleting my entire data set on the my phone)?
by
worked for me , thanks alot :)
by
Add a comment
Hold down volume up and down keys, and power button at the same time. Wait about 5 seconds, a recovery screen should pop up. Use the volume down key to select factory reset-this will erase all data on the phone. Press the home key to select, your phone should start the factory reset, then automatically restart when done. It takes a few minutes for the phone to restart. Then you can go through the setup like when the phone was new.
Score 1
Add a comment
I have a google account. I can login to both but neither provide the ability to reset your password, or unlock Samsung Galaxy S7 Edge without password. It seems both have completely feigned responsibility here, and as a result if anyone forgets their password then you are stuck. Unless you install some hacking program, which I assume compromises your phone in other ways.
Add a comment
Oops, sorry to hear about this.
But you don't need to worry about it. Simply Hard Reset your Samsung Galaxy S7 (this applies to all samsung phones) and it will enable Factory Reset Protection if you had signed in to Google Account on your device.
If you remember your email and password that you had used for Google Account, please enter that on your phone to remove FRP Lock.
In case you have also forgotten email and password, you will need to bypass FRP lock on Galaxy S7 phone. (this also works on all Samsung Phones)
Add a comment
Hold up and down the volume keys and simultaneously hold the power button. Wait about 5 seconds, there should be a recovery screen. To select factory reset, use the volume down key— this will erase all phone data. To select the home key, press the home key to start the factory reset, then restart automatically when done. It takes the phone a couple of minutes to restart. Then, as when the phone was new, you can go through the setup.
makemkv key
1 Comment:
How to unlock
by
Add a comment
Add your answer
caicaiys will be eternally grateful.
Past 24 Hours: 13
Past 7 Days: 60
Past 30 Days: 200
All Time: 716,190
