Keyboard Replacement for Toshiba Satellite Radius
Will someone put up a guide on how to replace a keyboard on a Toshiba Satellite Radius P55W?
Thanks in advance!
Thanks in advance!
Hi,
I don't know if the following two videos will be of any help, hopefully they will be.
This one shows how to open a Toshiba P55W laptop, but not how to remove the keyboard.
https://www.youtube.com/watch?v=XdzsayVU...
This one shows a fix for a keyboard problem in a Toshiba P55W laptop. It may not be your problem as you do not say what the problem is.
https://www.youtube.com/watch?v=eaBUdWEM...
If you still need to replace your keyboard, after watching these videos, you may to able to work out what else you have to remove to gain access to the keyboard.
These did not help. The keyboard is under the motherboard and there is no obvious way to get to it that I could figure out after removing the bottom cover.
I should add that the quick fix did work at one point for me but now the same set of keys don't work even after unplugging/plugging the cable. I got a replacement keyboard but there are no instructions that I could find for a keyboard like this where it's under a solid bezel. If anyone knows what to do please answer.
Satellite radius p55w-B5224 keyboard replacement I managed to do it. It is not easy!
Toshiba Satellite Radius P55W keyboard is attached to the top case. In order to replace Toshiba Satellite Radius P55W keyboard it's necessary to remove the motherboard.
Here's complete Toshiba Satellite P55W disassembly guide.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,424
