Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
What is my iPhone dying so quickly
When using my iPhone I usually charge my phone to 100%. However my phone tends to die around 70% to 90%. Then after a few minuets I turn it on to find it at around 70% to 90%. When it's not connected to a charger it would turn off right after the device has been powered on. i drained the battery but it would again power off if no charger is connected to the phone. I was wondering if I should buy another battery for the iPhone 6?
Score -1
Add a comment
1 Answer
Hi Eric
What may be beneficial for you is to contact a Apple Support Rep and get them to run diagnostics for you.
If your battery fails, then you can consider replacing the battery.
It is a common misconception that it is "good" to discharge your iPhone battery , lithium-ion batteries found in iPhones should not be discharged to the point of zero, it will shorten the battery life of your iPhone.
Regards
Brayden
Add a comment
Add your answer
Eric Del will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 120
